04-10-2011, 03:08 PM
amberectomy
Really alot easier than I thought... looks so good!
2000 Boxster S
2007 H3
04-10-2011, 03:38 PM
www.klisstle.com
Looks great!
Did you use a soldering iron or do it with just pliers, etc.?
04-10-2011, 03:46 PM
I used a soldering iron and pliers. Once i got everything ready, it was very easy....didnt even have to line the hole with foil....
2000 Boxster S
2007 H3
04-10-2011, 05:22 PM
FYI, Suncoast is selling the 550 red rear tail lights reduced at $139 for those looking to deamber tail lights.
04-10-2011, 06:00 PM
good deal, i no longer have any amber on the car....
2000 Boxster S
2007 H3
04-11-2011, 03:31 AM
Well done Kyle that's looking super clean
04-11-2011, 05:11 AM
Kyle, looks so nice and clean. How far in do you have to reach before you encounter the amber plastic? Just what holds the amber in place anyway?
Thanks for your posting.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
04-11-2011, 06:21 AM
Did you hold the amber lense with pliers and then melt it away so no pieces dropped? Did you let the pieces drop after melting them off?
986 00S
04-11-2011, 11:08 AM
AKL
The amber is right at the bulb hole. You don't have to reach in very far. I started poking a few holes in it and it came loose. Then I cut it up with the iron and pulled the pieces out. I had 1 or 2 small melted chunks fall down but I was able to remove them by shaking them out. I also vacumed the hole just to be sure. Really not a difficult job.
2000 Boxster S
2007 H3
04-11-2011, 11:25 AM
Looks good Kyle. Apparently I made the job sound more challenging that it really is, or maybe you're just that much better than me  We'll assume the former
2003 Boxster - Sold but not forgotten
04-11-2011, 02:12 PM
i think there might be some confusion about this process. the original assembly on vehicles < 2003 can't have the "amber" removed as it's actually the plastic that is yellow:
you must start with the lights from a 2003, or the litronics, which is clear in the turn signal with the amber glued to the reflector:
if i am misunderstanding, PLEASE let me know.
HTML code is Off
