-   -   amberectomy (http://986forum.com/forums/show-tell-gallery/28444-amberectomy.html)
kyleturner2020 04-10-2011 04:08 PM
amberectomy
Really alot easier than I thought... looks so good!
ddb 04-10-2011 04:38 PM
Looks great!
Did you use a soldering iron or do it with just pliers, etc.?
kyleturner2020 04-10-2011 04:46 PM
I used a soldering iron and pliers. Once i got everything ready, it was very easy....didnt even have to line the hole with foil....
JTP 04-10-2011 06:22 PM
FYI, Suncoast is selling the 550 red rear tail lights reduced at $139 for those looking to deamber tail lights.
kyleturner2020 04-10-2011 07:00 PM
good deal, i no longer have any amber on the car....
Christian H 04-11-2011 04:31 AM
Well done Kyle that's looking super clean :cool:
Allen K. Littlefield 04-11-2011 06:11 AM
Kyle, looks so nice and clean. How far in do you have to reach before you encounter the amber plastic? Just what holds the amber in place anyway?
Thanks for your posting.
AKL :cheers:
jaykay 04-11-2011 07:21 AM
Did you hold the amber lense with pliers and then melt it away so no pieces dropped? Did you let the pieces drop after melting them off?
kyleturner2020 04-11-2011 12:08 PM
AKL :cheers:
The amber is right at the bulb hole. You don't have to reach in very far. I started poking a few holes in it and it came loose. Then I cut it up with the iron and pulled the pieces out. I had 1 or 2 small melted chunks fall down but I was able to remove them by shaking them out. I also vacumed the hole just to be sure. Really not a difficult job.
timothy 04-11-2011 12:25 PM
Looks good Kyle. Apparently I made the job sound more challenging that it really is, or maybe you're just that much better than me ;) We'll assume the former :D
tonycarreon 04-11-2011 03:12 PM
i think there might be some confusion about this process. the original assembly on vehicles < 2003 can't have the "amber" removed as it's actually the plastic that is yellow:
http://www.partsgeek.com/assets/rep/...86-1057265.jpg
you must start with the lights from a 2003, or the litronics, which is clear in the turn signal with the amber glued to the reflector:
http://www.partsgeek.com/assets/rep/...85-1058317.jpg
if i am misunderstanding, PLEASE let me know.
