Performance and Technical Chat
That Dang Spot on the Floor....
12-14-2006, 11:32 AM
UroTrash
If you have a RMS leak will thinner oil (i.e. M-1 Zero-W40) leak worse than thicker oil (say, 10-W40)?
12-14-2006, 01:29 PM
2
wvicary
Renntech had a thread on this..... RMS leak just as much with 0W40 as they do with 15W40. Often it's a combination of the intermediate shaft housing seal and RMS that leaks.
12-14-2006, 02:12 PM
3
blue2000s
Porscheectomy
Using a thicker oil isn't the right answer to fixing a leak. It will cause other long term issues.
12-14-2006, 02:37 PM
4
Ronzi
I think by the time it gets heated up, it's all going to be about the same weight, anyway.
12-14-2006, 03:07 PM
5
blue2000s
Porscheectomy
Originally Posted by
Ronzi
between 0-40 and 10-40, that's true.
12-18-2006, 04:28 PM
6
UroTrash
Problem solved:
UroTrash's RMS repair
Linear Mode
Switch to Threaded Mode
11:04 AM
