Old 12-14-2006, 12:32 PM   #1
That Dang Spot on the Floor....
If you have a RMS leak will thinner oil (i.e. M-1 Zero-W40) leak worse than thicker oil (say, 10-W40)?
UroTrash is offline   Reply With Quote
Old 12-14-2006, 02:29 PM   #2
Renntech had a thread on this..... RMS leak just as much with 0W40 as they do with 15W40. Often it's a combination of the intermediate shaft housing seal and RMS that leaks.
wvicary is offline   Reply With Quote
Old 12-14-2006, 03:12 PM   #3
Porscheectomy
Using a thicker oil isn't the right answer to fixing a leak. It will cause other long term issues.
Old 12-14-2006, 03:37 PM   #4
Ronzi's Avatar
I think by the time it gets heated up, it's all going to be about the same weight, anyway.
Ronzi is offline   Reply With Quote
Old 12-14-2006, 04:07 PM   #5
Porscheectomy
between 0-40 and 10-40, that's true.
Old 12-18-2006, 05:28 PM   #6
Problem solved:
UroTrash's RMS repair
