Old 12-13-2023, 06:11 PM   #1
986 wheel uprights
Hi
I have a great set of 987 struts that I want to install on a 986..I know the lower hole, where the strut inserts on the front it too small..can 987 wheel carriers be swapped. I am told the rear is the same
I don't know if I can machine out the 986 carriers to make the 987 tubes fit
BOXSTERLESS is offline   Reply With Quote
Old 12-13-2023, 08:16 PM   #2
There are shims or spacers available. Reach out to some of the bigger name companies. My JRZs on the 996 have a sleeve that makes them fit the 996 upright. I’m sure other companies have similar sleeves.
Shawn
-1999 Boxster 3.4L swap/NHP Headers/Fabspeed maxflow/ Coilovers/GT3 arms/adj. rear toe links/Tarret front and rear bar/UIDS/UAOS
-2002 911 Turbo -JRZ RS Pro/GMG swaybars/RSS/Billet k16s/ Markski turbo inlet pipe, tune, 3” exhaust, intercoolers/GT3 seats w/red GT3 belts/CCW classics
Sveach756 is offline   Reply With Quote
Old 12-14-2023, 04:50 AM   #3
sveatch..please check you car models...I have a 986(2001) boxster and a set of struts from a 2016 caymen (987) avaiable..
Old 12-14-2023, 05:59 AM   #4
Motorist & Coffee Drinker
78F350's Avatar
Not sure if the 987 carriers easily swap, but I may have time to check it out on a car next week.
I think that the VW MK6 struts that Woody used have the same diameter as the 987 struts and he successfully milled it to fit. 6 months to live build thread
