Old 01-20-2023, 11:47 AM   #1
Paddle shifters
I think I have this right but wanted to throw it out and get confirmation. The paddle shifters on the steering wheel are momentary switches that provide a ground to whichever action is chosen by the driver actuating the switch (upshift/downshift). Does anybody know the voltage that is present on the individual single wires going to the switch? I am having a problem with mine not working and wanted to start at the wheel and work backward. Thanks in advance.
Dllrd23 is offline   Reply With Quote
Old 02-22-2023, 03:01 PM   #2
Paddle shifters
The Bently 986 shop manual has great wiring diagrams. I have found it very valuable in tracing out circuits. All the voltage will be 12 VDC. With a DMM you can read wires to ground on the DC voltage side and also find grounded wires with continuity.
It makes things way easier when you have a schematic.
Plato986 is offline   Reply With Quote
Old 02-23-2023, 02:29 AM   #3
I know some modules use a 5v ref signal but that is usually to some sort of variable resistor with a return line. I don’t think that is the case here I was just wondering if there should be any voltage present or if it is just completion of the ground circuit. Bentley and ProDemand diagrams don’t specify which it is. I guess I just have to get in there and check it both ways taking care not to fry the transmission control module. That’s for your reply. I will post a follow up here in case anyone is curious.
Old 02-23-2023, 12:53 PM   #4
78F350's Avatar
I have paddles that I plan to install, but it's way down on my project list. At the TCU, pin (46) BR/YE is up-shift and (47) BR/BK is down-shift. Those are wired to the switches and are switched to ground. At the steering wheel on the '01 I looked at the BR/BK wire becomes BR/RD from the column harness. At idle with the brake applied I measured a little over 11V at the steering wheel harness on both.
Old 02-23-2023, 02:16 PM   #5
11v is the answer I’m looking for. I fully expect there to be 0 v at the wheel as mine are inop. Originally thought it may be a ground or click spring as they are in common with the horn that wasn’t working but I found a blown fuse for the horn and it works now (eliminate ground from the thought process). Anyway, I’m going after it this weekend as I am still waiting for intake bolts from FPC EURO for 11 days😖. Thanks again for your help.
