Old 11-24-2022, 08:50 AM   #3
Registered Member
I had the same issue with my 2004 S. After checking fuses and taking the lnstrument cluster apart and not finding replaceable bulb I learned of the headlamp switch as a possible root cause. The other symptom was no dimmer adjustment screen would pop up. I replaced the switch which resolved the problem.
muledog is offline   Reply With Quote
