Old 06-09-2021, 03:13 AM   #1
Panel switches
Has anyone seen any after market rocker switches that would fit here and look OEM?
I'd like to wire the headunit through it. Currently I need ignition on but a rocker switch would be handier and radio could be on without the key if I wanted.
Probably not any available but thought I'd check.
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
Traco is offline   Reply With Quote
Old 06-09-2021, 04:42 AM   #2
What year is that? I haven't seen a center console that doesn't have the buttons slanted.
You can find a bunch of different types of switches for sale. There's a targa roof button for example that closely resembles a garage door. 996-613-119-10-A05-OEM. Or one to activate the rear spoiler. 996-613-155-00-A02-OEM. These aren't cheap though. I've never seen an aftermarket company make one.
I've also seen at least one post where a guy used a blank and made a functioning switch out of it. I search may help you.
Btw, I too have been toying with the idea or a push start button. Where I'm at right now is removing the ignition switch all together and running the "run" function on a flip switch and then ignition would be a push button. Kinda rocket-ship-esque.
Sent from my POCOPHONE F1 using Tapatalk
Old 06-09-2021, 05:26 AM   #3
It's a 2003 S.
They have a nice dome profile on one side but they aren't latching - press once and let a relay do its thing or press and hold like for the roof.
I'm not surprised there isn't an after market one but worth asking. I could get an OEM blank and play with it or get a relay and make it work. Its not an important job anyway, just too lazy to go look for another switch source on the fuse panle as I used one that was for an aftermarket phone kit.
Traco
_________________
Older but no wiser.
Old 06-09-2021, 05:31 AM   #4
There Is No Substitute.
rick3000's Avatar
No aware of any aftermarket switches that will fit. You could use a different OEM switch, although depending on the application it might require a latching relay, and you need to make sure the OEM switch has the correct internal wiring for your application.
I did see one person who took a switch blank and cut the top off and glued it to an aftermarket switch, then mounted that, but it was all custom.
