Thread: Panel switches
Old 06-09-2021, 06:31 AM   #4
rick3000
There Is No Substitute.
rick3000's Avatar
No aware of any aftermarket switches that will fit. You could use a different OEM switch, although depending on the application it might require a latching relay, and you need to make sure the OEM switch has the correct internal wiring for your application.
I did see one person who took a switch blank and cut the top off and glued it to an aftermarket switch, then mounted that, but it was all custom.
rick3000 is online now   Reply With Quote
