Thread: Panel switches
Old 06-09-2021, 04:42 AM   #2
ike84
Originally Posted by Traco View Post
Has anyone seen any after market rocker switches that would fit here and look OEM?
I'd like to wire the headunit through it. Currently I need ignition on but a rocker switch would be handier and radio could be on without the key if I wanted.
Probably not any available but thought I'd check.
What year is that? I haven't seen a center console that doesn't have the buttons slanted.
You can find a bunch of different types of switches for sale. There's a targa roof button for example that closely resembles a garage door. 996-613-119-10-A05-OEM. Or one to activate the rear spoiler. 996-613-155-00-A02-OEM. These aren't cheap though. I've never seen an aftermarket company make one.
I've also seen at least one post where a guy used a blank and made a functioning switch out of it. I search may help you.
Btw, I too have been toying with the idea or a push start button. Where I'm at right now is removing the ignition switch all together and running the "run" function on a flip switch and then ignition would be a push button. Kinda rocket-ship-esque.
Sent from my POCOPHONE F1 using Tapatalk
