Old 12-20-2011, 07:11 PM   #1
Code Read with Durametric
First of all I think this tool is great. Never user one so I'm very glad that I can now read the faults in the vehicle and diagnose issues. Haven't played around too much with it but here's what I did so far:
- checked the fault codes on all supported features of the car. Pretty comprehensive. Does show you options what you don't have. Parking assist for example which I don't have.
- Was able to manually command start and stop of various components, radiator fans, CEL light etc. Good to make sure things are working.
- Tried to test the Xenon lamp and issued a error that component was not present. True, I have OEM HID.
- Did not reset the codes to see if they are old or still valid. Wish it ave me a date stamp on the error.
It did fail me on the readiness which I believe is what you could use to determine if you will pas the DMV inspection. Mine fails miserably. Some other faults are due tomthings that PO did. Replaced stock seats with sport and disconnected harness, did some hot wiring to alarm to do something with the radio etc. But the O2 sensors bother me. I did see the one by cylinder 4-6 was dripping with engine oil. Cleaned it but might have to replace after I change the coil tubes.
Below is the work log from the program. More to come later.
Bosch Digital Motor Electronics Motronic 7.2
Module Identification
Part Number 986.618.660.03
Supplier Part Number 004157026450
Current Fault Codes
P1576:
Porsche fault code 274 - Cruise control readiness light via CAN exceeds limit value
P1119:
Porsche fault code 5 - Heating power O2S ahead of cat. c. bank 2
P1128:
Porsche fault code 360 - Oxygen sensing adaptation idle range bank 1
P0150:
Porsche fault code 18 - O2 sensor ahead of cat. conv. Cylinder (4-6)
P0442:
Porsche fault code 97 - Fuel tank ventilation minor leak below limit value
ABS/PSM 5.3
Part Number 996.618.135.01
Supplier Part Number 02730041780246
Current Fault Codes
No Faults Found
Airbag B05
Part Number 996.618.219.01
Supplier Part Number B05
Current Fault Codes
3:
Supply voltage
73:
Child seat detection
1:
Airbag warning light
Automatic Air Conditioning H01
Part Number 996.653.101.03
Supplier Part Number 36
Current Fault Codes
20:
Combi-interface fault
21:
Ambient temperature sensor fault (intake duct)
22:
Instrument panel temperature sensor fault
23:
Footwell blow-off sensor fault
26:
Mixing flap motor fault
27:
Central flap motor fault
28:
Footwell defr. flaps motor fault
29:
Outs./recirc. air fl. mot. fault
31:
Fresh air blower fault
33:
Sun sensor fault
Alarm I32
Part Number 996.618.260.07
Supplier Part Number 080504003007
Current Fault Codes
49:
K lead
Status: not present
Occurance Counter: 3
This fault is displayed for informational purposes, it is not an indication of a problem and no repair is needed.
11:
Voltage failure during alarm output
Status: not present
Occurance Counter: 1
10:
Voltage failure at terminal 30 with alarm system active
Status: not present
Occurance Counter: 2
33:
Interior sensor faulty
Status: not present
60:
Central locking limit position Lock not reached
Status: not present
Occurance Counter: 9
Current Fault Codes
P1576:
P1119:
P1128:
P0150:
P0442:
ABS/PSM 5.3
Current Fault Codes
No Faults Found
ABS/PSM 5.3
Current Fault Codes
No Faults Found
