Old 12-04-2020, 03:40 PM   #17
Originally Posted by FredinVa View Post
Hi everybody,
Chain guides were mentioned, can that be done without major disassembly?
What other parts would you recommend a used engine get before installation?
Thanks again!
I`d only replace the small chain pads in the head, 4 pieces in total. If the engine is out it`s a fairly easy job, you just need to lock the cams and crank at TDC with some special tools and pull the head covers then remove the actuator-camshaft asssembly, replace the pads, then put everything back on and set the timing. Check my build thread, there`s some info about this job. I`d check the water pump and all the components of the SAI system, that`s also a common failure point and it`s much easier to get access to it when the engine is out.
