Old 04-22-2020, 02:14 AM   #1
Newbie
If you turn the ac on you should hear the low speed fans kick on immediately. I believe the coolant temperature threshold for the high speed fans is 206 degrees.
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 04-22-2020, 04:08 PM   #2
^^ What he said. ^^
The fans should come on at low speed as soon as the A/C is turned on. Check both sides. If one or both doesn't turn on, then you have a problem.
Old 04-23-2020, 04:56 PM   #3
PorscheBear86's Avatar
Thank you I will try this I appreciate your help!
PorscheBear86 is offline   Reply With Quote
Tags
cooling fans
