Old 04-21-2020, 04:44 PM   #1
PorscheBear86's Avatar
Cooling Fans Not running correctly?
Hello.
My car is a 2001 Boxster 2.7 base. 150k miles
I replaced the water pump and thermostat with a 160 lower temp.
it was running fine and cooling correctly after?
My question is. After sitting all winter the fans do not seem to kick on while the car is running or even after its off and hot or slightly above 180. Its worrying.
I hooked up my Durametric tool and laptop. I can turn on all fans and they sound normal.
But when the car is running on its own with out the durametric the fans do not seen to ever turn on.??
please help.
PorscheBear86 is offline   Reply With Quote
Old 04-21-2020, 07:40 PM   #2
elgyqc's Avatar
What temperature was it outside last year when you noticed the fans running? Looks like it is a bit cool in Pittsburgh so maybe it doesn't need the fans... yet. My fans only stay on after the engine is shut down in summer temperatures. I'll check tomorrow, but I don't think 180 is overly hot.
Grant
Old 04-21-2020, 10:08 PM   #3
bcrdukes's Avatar
If you're in stop and go traffic, or just idling, at some point in time, the radiator fans will kick in. I don't recall the threshold exactly, so hopefully someone will chime in on the specifics.
The worst case scenario is that the relays have failed, but does not appear to be the situation given that your Durametric was able to enable them on command.
2001 Porsche Boxster S
bcrdukes is offline   Reply With Quote
Old 04-22-2020, 02:14 AM   #4
Newbie
If you turn the ac on you should hear the low speed fans kick on immediately. I believe the coolant temperature threshold for the high speed fans is 206 degrees.
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 04-22-2020, 04:08 PM   #5
^^ What he said. ^^
The fans should come on at low speed as soon as the A/C is turned on. Check both sides. If one or both doesn't turn on, then you have a problem.
Old 04-23-2020, 04:56 PM   #6
Thank you I will try this I appreciate your help!
Old 04-23-2020, 04:57 PM   #7
Ok thanks for your help it is cooler here
Old 04-23-2020, 04:59 PM   #8
Ok thanks I might just be worried about nothing I guess
Tags
cooling fans
