Old 04-20-2020, 08:40 PM   #2
1999 base
Meir's Avatar
Originally Posted by geraintthomas View Post
Quick question:
This is a relay pulled from a thread of someone who used a latching relay to turn a ground wire into a switched ground wire.
How would I wire that so that it has a constant ground, but the result is a switched positive?
Should be a simple answer but I'd rather not guess!
Many thanks.
56 will be your output.
56a 56b will be positive an negative. You can flip them depends on the polarity you want to use for the trigger (S).
If uour trigger is negative, then 56b will be positive.
