Old 04-16-2020, 02:50 PM   #1
geraintthomas's Avatar
Latched relay question
Quick question:
This is a relay pulled from a thread of someone who used a latching relay to turn a ground wire into a switched ground wire.
How would I wire that so that it has a constant ground, but the result is a switched positive?
Should be a simple answer but I'd rather not guess!
Many thanks.
Porsche Boxster S Type 986
Old 04-20-2020, 08:40 PM   #2
1999 base
Meir's Avatar
Originally Posted by geraintthomas View Post
Quick question:
Many thanks.
56 will be your output.
56a 56b will be positive an negative. You can flip them depends on the polarity you want to use for the trigger (S).
If uour trigger is negative, then 56b will be positive.
Old 04-21-2020, 12:29 AM   #3
Oh, that's interesting - I already had an answer from boxa.net and was this:
Is that not right?
Old 04-21-2020, 08:19 AM   #4
1999 base
Meir's Avatar
it should work if you only need to turn positive pulse to constant.
i guess i misunderstood your original post.
Old 04-21-2020, 11:40 AM   #5
1999 base
Meir's Avatar
BTW, the diagram on the relay is a bit confusing, and not accurate.
in reality legs 56a and 56b are isolated from each other.
go by this one.
