03-29-2020, 06:46 PM
Tachometer Signal
Gents,
Where is the best place to connect to the tachometer signal. I ask as I a have the cluster apart and have access to the plugs at the back.
From the wiring diagrams (1998) I have and posts it appear that it is plug II (white), gr/vi (I think this is green/violet; I hope I can actually discern the colours). I could solder a pin and insert into to the connector. This will be a bit messy.
Which OBDII wire is the tachometer signal? Would it be better wiring practice to use a wire tap (if so which type) and just grab switched 12v there as well? The wires I am trying to connect up are a very fine gauge.
A present it would be easier to order wire taps online rather that grabbing soldering equipment.
j
986 00S
04-03-2020, 09:15 AM
Crickets.........no one?
986 00S
04-03-2020, 11:30 AM
Check the ODB2 plug pin 9 Purple Green
04-04-2020, 07:21 AM
tach connections
I have a question about doing just the opposite.
My engine swap is using a stand alone ECU that has a 5V tach driver output. As I'm not using the factory ECU to make the engine run, can I back feed the 5 volt signal into the same OBD wire to make the tach in the dash work?
I'm aware of the Tach Adapt product but I still need to find out what wire or wires feed the tach itself. 01 Boxster S 6 speed. I have the Bentley manual and wiring diagram but my eyesight is just not that good anymore.....
Thanks for any thoughts!
04-04-2020, 06:46 PM
Thanks man. This matches with the cluster wire colour which is good news. There was nothing I could find wiring diagram-wise. By any chance can are you aware of which OB2 pin/wire colour is switched 12V???
986 00S
04-05-2020, 07:10 PM
I am leaving the factory ECU in tack so I can run all these little things like coolant temp yada yada. Might not be the "cleanest" solution but I think it should work.
If leaving the ECU in place doesn't work; I'm gonna follow this thread for a solution.
'98 PP13B powered "RX986"
04-06-2020, 07:15 AM
I used the wire in the center console under the radio Its a 4 pin plug that also has a ground. Green/Black switched 12, Red/Green 12vdc always, Brown GND.
ODB2 pin 16 Red/Black
04-06-2020, 07:37 AM
I used this for my Traqmate system, until I started to have compatibility problems with GoPro. I switched to AIM with ODB2 bluetooth which was easier mating video to data and direct connect sensor.
04-06-2020, 08:39 AM
If you do end up using a tap, search for posi-tap connectors, they are way better than the blade style ones that pinch onto the wire. When I wired my trailer hitch, the blade connectors that came with my harness were junk and worked intermittently, so I replaced them all (except passenger side turn signal) with the posi-tap connectors. Guess which one doesn't work reliably these days
Disclaimer: Maybe the blade taps that came with my harness were junk and other brands are better, but I really like the posi-tap connectors.
04-07-2020, 01:28 PM
Thanks Steve! I was doing some surfing (not the kind I want to be doing on Coco Beach) and came to this conclusion. Thanks for confirming my arm chair thoughts with practical experience. Here is a link for everyone's benefit:
https://www.posi-products.com/
These things still use a spike going in the stands but my feeling is that they would yield way less damage while having less potential for an intermittent condition
986 00S
04-07-2020, 01:42 PM
Originally Posted by Quadcammer
Thanks Quad, yes this is exactly where I am going with this....If I can secure all the materials required for the install during these times, fI will post up the results.
Currently looking for a remote 3D printer for small stuff and then have them mail back the hardware.
986 00S
04-07-2020, 01:51 PM
Beautiful yes, I think you are referring to the black connector pictured here in mid-frame. I would dearly love to find a connector that goes in and slice into those leads for all the add ons I am putting in. Any mistakes would not harm the stock harness.
Did you find pins that fit in there?
986 00S
