Old 12-27-2019, 08:54 PM   #4
AZ986S's Avatar
Well my friend, you are not alone... Nothing to do with the Accusump, just human error in this case.
When I get another engine back into the car, maybe I'll tear the block down and see what kind of damage complete oil starvation does to an M96 engine I guess my question would be if the camshaft/head cover journals are damaged or still usable. There was certainly a heavy rod knock and low oil pressure light.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
