Old 12-27-2019, 11:33 AM   #1
truegearhead's Avatar
Motor ran without oil. Toss it or rebuild?
Last season I lost an accusump line and ran the car completely out of oil because I’m an idiot. I’ve since swapped it out with a 2.7 but still have the old motor sitting around. It still runs but even with new oil in it you can hear the bearings. Are these worth rebuilding? Can I do anything creative like install a 3.6l crank? It’s an early 2.5
Cheers,
Stu
2003 911 C2
NASA HPDE Instructor
Old 12-27-2019, 02:01 PM   #2
BYprodriver's Avatar
Cheers,
Stu
Definitely no 3.6L cranks, I have a set of NOS Porsche rod bearings for sale if you need them.
Old 12-27-2019, 05:55 PM   #3
Qingdao's Avatar
I'm just gonna toss my old 2.5 block (IMS failure) at the local European shop. If they give me like $500 I'll take it. If not it becomes a coffee table.
That's my plan, but you might split yours open and find the bores clean and nothing warped or too badly mangled.
'98 PP13B powered "RX986"
Old 12-27-2019, 07:54 PM   #4
AZ986S's Avatar
Well my friend, you are not alone... Nothing to do with the Accusump, just human error in this case.
When I get another engine back into the car, maybe I'll tear the block down and see what kind of damage complete oil starvation does to an M96 engine I guess my question would be if the camshaft/head cover journals are damaged or still usable. There was certainly a heavy rod knock and low oil pressure light.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 12-28-2019, 06:40 AM   #5
Artist, 986S tinkerer
NewArt's Avatar
Cheers,
Stu
If you have the space and the time, you might consider tearing it down. You can see whether it can be easily salvaged assuming, of course, that you can do it yourself. If it were a 3.2 it would be worth putting some effort and money into it but I wouldn’t imagine that there’s a lot of call for a 2.5. I’ve done a couple of teardowns which you can see on my YouTube channel: https://www.youtube.com/user/12shoes2
Old 12-28-2019, 01:16 PM   #6
Usually the rod bearings are the 1st to go followed by the crankshaft rod surfaces soon after. Good crankshafts are getting hard to find & expensive.
