Old 10-12-2019, 02:33 PM   #1
Shapeshifting Lizard-Man
WizardSmokey's Avatar
Transmission fitment question
What engines will bolt up to the 986 5 spd? What exact transmission is it? I've been googling it for the past hour and all I could find is that it's an Aisin, but I couldn't confirm that or the specific transmission.
Basically, the 2.7 in my 986 has one foot in the grave, and i'm looking for engine swap options that won't end up costing more than a new M96 and/or require fabricating the whole back half of the car.
WizardSmokey is offline   Reply With Quote
Old 10-13-2019, 11:33 AM   #2
Kennedy has an adapter to bolt an LS to both of the Boxster manuals
I think some of the VW/Audi engines use the same bolt pattern also?
Chi-Town is offline   Reply With Quote
Old 10-13-2019, 02:02 PM   #3
After some research, it would seem that the transmission is referred to as the G86/01.
My next question, is the bolt pattern of the G86 the same as the G96 out of the carrera of the same years? It seems like it is, but I want to make sure before committing to anything.
Old 10-13-2019, 05:31 PM   #4
Porsche "Purist"
Paul's Avatar
Bolt pattern is the same (same block) but do you want 5 speeds in reverse?
1987 924S. 2002 996TT. PST-2
Old 10-13-2019, 06:53 PM   #5
elgyqc's Avatar
Good point!
Grant
elgyqc is offline   Reply With Quote
Old 10-13-2019, 07:22 PM   #6
The reason I'm asking is because I found a site that makes an adapter for the G96 transaxle. Making sure it will bolt to the G86.
Old 10-14-2019, 06:19 AM   #7
bolt pattern is the same. The g86 is not an aisin gearbox, I believe its getrag. VW engines will bolt up if you're looking at a 1.8t swap or Audi V8.
Old 10-14-2019, 07:27 AM   #8
piper6909's Avatar
Why is that? Do the motors run in the opposite rotational direction?
Old 10-14-2019, 08:47 AM   #9
no, but if you point it in the other direction, the gears will turn the wheels in the opposite way.
Old 10-14-2019, 11:45 AM   #10
piper6909's Avatar
Ah, so the Carrera's engine & tranny are oriented backwards, like a VW Bug?
Old 10-15-2019, 05:47 PM   #11
Kitcarchassis has them as well. I have an LS adapter on order for mine.
outsidetheboxster is offline   Reply With Quote
Old 10-19-2019, 03:36 PM   #12
I ended up talking to a place called Kennedy Engineering, seems like they do some adapters for Porsche transaxles to various other engines.
