Old 10-04-2006, 10:35 AM   #1
**URGENT** new boxster owner, help needed.
HI,
sorry if im over reacting
but ive only had my 986 a week
and i noticed today when i come home from work there was water driping from the front ride side of the car and steam/smoke coming from grill(radiator is located?)
wasnt dripping alot. just noticed a little wet patch afetr an hour of it sitting there is this normal for boxsters to do this?
maybe something todo with an overflow?
i dont know much about, but im worried now.
any help would be magic, as i want advice before i take it to porcshe and get rapped for a high bill
thanks for reading
dave
myers is offline   Reply With Quote
Old 10-04-2006, 10:40 AM   #2
Send a message via MSN to CJ_Boxster
Geez, your only good option is to take it to the dealer and have them check the hose clamps and radiator for leaks. Unless you want to get on your back and do it yourself.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 10-04-2006, 10:45 AM   #3
Examine the wet patch. If it's clear, it may just be condensation from running your AC in hot weather.
Now if it's colored liquid, that's radiator fluid. Especially if you are seeing steam I would say you need to have it examined immediately and do not continue to drive the car.
Last thing you want to do is run low on coolant and overheat a very, very expensive engine.
While you have the car in the shop, have the mechanic go over it with a fine tooth comb... it will be the best money you ever spent. Knowing up front what's worn and what will need replacement always helps a new Porsche owner sleep better at night.
Old 10-04-2006, 11:07 AM   #4
it is anti freeze because it tastes sweet. and i havent had my ac on.
anyone know how to get those little things of inside the arch to take the black mud guardthingy so i can have a proper look at it
Old 10-04-2006, 11:13 AM   #5
ohioboxster's Avatar
Ths is in another thread but its pretty simple DIY if you have 2 hours or so.
http://www.realtime.net/~rentner/Porsche/Radiator/Radiator.html
Once you get the bumper cover off you will have a great look at the radiators.
2002 TT
ohioboxster is offline   Reply With Quote
Old 10-04-2006, 11:15 AM   #6
Myers, don't be tasting too much of that stuff. It'll kill you
