Old 10-13-2019, 10:30 AM   #1
truegearhead's Avatar
Installed new engine. Now no electrical power. I’m stumped
I just finished swapping a replacement motor in, went to crank it over after taking the battery off of the charger and turning the key I have no electrical power at all. No lights turn on, nothing. It’s like there’s no battery installed at all. I’ve checked and rechecked everything I’m not sure what I did. I know it could be anything but any ideas?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 10-13-2019, 11:30 AM   #2
Porsche "Purist"
Paul's Avatar
Check your current distributor fuses.
1987 924S. 2002 996TT. PST-2
Old 10-13-2019, 11:33 AM   #3
Porsche "Purist"
Paul's Avatar
Part 10
Old 10-13-2019, 02:21 PM   #4
Great thanks! I’ve searched and searched and can’t figure out how to access this thing. I know it’s on the bulk head, do I access it from the airbag cover?
2003 911 C2
Old 10-13-2019, 02:48 PM   #5
Motorist & Coffee Drinker
78F350's Avatar
The current distributor may be accessible behind/below the HVAC fan unit. Airbag? We die like real men - Delete it. AC and Heat is for the weak. Just pull all that stuff out.
Looking thru the airbag space at the white plastic box:
Looking a little upward below the dash:
Old 10-13-2019, 02:54 PM   #6
Haha, thanks man. The airbags went loooong ago. It’s a fully caged car so hopefully the crash bar under the dash isn’t screwing me here. Thanks for the info! I’m crawling in.
2003 911 C2
Old 10-13-2019, 04:32 PM   #7
Porsche "Purist"
Paul's Avatar
The torque specs for the connections should be stamped on the inner lid. Use new hardware.
Old 10-14-2019, 04:24 AM   #8
False alarm, turns out the relay box in the trunk was unplugged. No idea why. The engine started right up but is leaking oil like hell and has a power steering leak. Still progress! Thanks again for your help
2003 911 C2
