-   -   Installed new engine. Now no electrical power. I’m stumped (http://986forum.com/forums/performance-technical-chat/76415-installed-new-engine-now-no-electrical-power-i%92m-stumped.html)
truegearhead 10-13-2019 09:30 AM
I just finished swapping a replacement motor in, went to crank it over after taking the battery off of the charger and turning the key I have no electrical power at all. No lights turn on, nothing. It’s like there’s no battery installed at all. I’ve checked and rechecked everything I’m not sure what I did. I know it could be anything but any ideas?
Paul 10-13-2019 10:30 AM
Check your current distributor fuses.
https://cimg5.ibsrv.net/gimg/rennlis...b514e3ff88.jpg
Paul 10-13-2019 10:33 AM
Part 10
https://www.design911.co.uk/uploads/...2005-08No6.gif
truegearhead 10-13-2019 01:21 PM
Great thanks! I’ve searched and searched and can’t figure out how to access this thing. I know it’s on the bulk head, do I access it from the airbag cover?
78F350 10-13-2019 01:48 PM
The current distributor may be accessible behind/below the HVAC fan unit. Airbag? We die like real men - Delete it. AC and Heat is for the weak. Just pull all that stuff out. ;)
Looking thru the airbag space at the white plastic box:
https://live.staticflickr.com/65535/...60d55207_c.jpg
Looking a little upward below the dash:
https://live.staticflickr.com/65535/...111666ae_c.jpg
truegearhead 10-13-2019 01:54 PM
Haha, thanks man. The airbags went loooong ago. It’s a fully caged car so hopefully the crash bar under the dash isn’t screwing me here. Thanks for the info! I’m crawling in.
Paul 10-13-2019 03:32 PM
The torque specs for the connections should be stamped on the inner lid. Use new hardware.
truegearhead 10-14-2019 03:24 AM
False alarm, turns out the relay box in the trunk was unplugged. No idea why. The engine started right up but is leaking oil like hell and has a power steering leak. Still progress! Thanks again for your help :cheers:
