Old 08-20-2019, 10:14 PM   #1
Urethane Transaxle Mounts - Good?
Anyone have these?
https://www.uspmotorsports.com/Torque-Solution-Engine-Mount-Kit-Porsche-Boxster-Cayman.html?utm_source=google&utm_medium=cpc&adpos=1o7&scid=scplpTS-POR-009&sc_intid=TS-POR-009&gclid=CjwKCAjwtO7qBRBQEiwAl5WC27-5HkrxYWfuezTCMigBQqAv_b8-XLRn8aKCTZD8gE_EisjyLWWQAhoCmv8QAvD_BwE
If so, what do you think?
Silber
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
Old 08-21-2019, 05:33 AM   #2
Who's askin'?
maytag's Avatar
Those are interesting to me, as well. However they don't list any for the 986. Are the 987 units similar enough?
Old 08-21-2019, 06:03 AM   #3
steved0x's Avatar
I think they are, I have the Wevo version on my Boxster and I plan to move them to my Cayman when I get a chance, according to the Tarett site (where I got them) they are compatible:
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-engine~trans~brakes~elect-/semi-solid-964-993-eng-mount-detail.htm
Old 08-21-2019, 09:06 AM   #4
i used 964 RS engine mounts as my tranny mount. they work good.
Old 08-21-2019, 10:48 AM   #5
Who's askin'?
maytag's Avatar
Like these?
https://www.pelicanparts.com/More_Info/96437504381.htm?pn=964-375-043-81-M253&gclid=EAIaIQobChMIj4vD18KU5AIVcRh9Ch0c7whzEAQYAiAB EgKUF_D_BwE
Old 08-21-2019, 01:39 PM   #6
edc
550 Anniversary
edc's Avatar
You can also remove the hydraulic fluid in the OE mount and fill with poly. For even more firmness fill with poly around the stud the other side too.
Old 08-21-2019, 05:52 PM   #7
Who's askin'?
maytag's Avatar
Glad this came up. Just did that tonight. I'll hope to install the motor tomorrow, then. ;-)
Old 08-21-2019, 05:53 PM   #8
Yes exactly that
Old 08-24-2019, 05:21 AM   #9
edc
550 Anniversary
edc's Avatar
https://imgur.com/H5EOa1u
Old 08-25-2019, 09:30 AM   #10
I looked into these, they’re only $80-$100 a pair which is good, but you need $100+ worth of Porsche bolts to make them work, so they are about $200 for the set up. So, the urethane ones are only about $70 more, so I’m thinking those might be the way to go.
Silber
Old 08-26-2019, 01:00 PM   #11
Silber
no sir. You need roughly $15 worth of porsche washers and another $15 from www.boltdepot.com for the bolts.
porsche bolts are nothing special. If i was more than $115 into my tranny mounts, i'd be surprised.
Old 08-29-2019, 09:27 PM   #12
I also have the Wevo units. They do transmit a higher level of vibration to the chassis than the stock mounts. I can see the vibrations in my side mirror.
Old 08-30-2019, 07:05 AM   #13
1998 Boxster Silver/Red
Sir, they have the "P" on them. Clearly that is worth something.
1998 Porsche Boxster
