08-20-2019, 09:14 PM
#1
Urethane Transaxle Mounts - Good?
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
08-21-2019, 04:33 AM
#2
Who's askin'?
Originally Posted by Silber
Those are interesting to me, as well. However they don't list any for the 986. Are the 987 units similar enough?
08-21-2019, 08:06 AM
#4
i used 964 RS engine mounts as my tranny mount. they work good.
08-21-2019, 09:48 AM
#5
Who's askin'?
08-21-2019, 12:39 PM
#6
550 Anniversary
You can also remove the hydraulic fluid in the OE mount and fill with poly. For even more firmness fill with poly around the stud the other side too.
08-21-2019, 04:52 PM
#7
Who's askin'?
Glad this came up. Just did that tonight. I'll hope to install the motor tomorrow, then. ;-)
08-21-2019, 04:53 PM
#8
Originally Posted by maytag
Yes exactly that
08-24-2019, 04:21 AM
#9
550 Anniversary
08-25-2019, 08:30 AM
#10
I looked into these, they’re only $80-$100 a pair which is good, but you need $100+ worth of Porsche bolts to make them work, so they are about $200 for the set up. So, the urethane ones are only about $70 more, so I’m thinking those might be the way to go.
Silber
08-26-2019, 12:00 PM
#11
Silber
no sir. You need roughly $15 worth of porsche washers and another $15 from www.boltdepot.com for the bolts.
porsche bolts are nothing special. If i was more than $115 into my tranny mounts, i'd be surprised.
08-29-2019, 08:27 PM
#12
I also have the Wevo units. They do transmit a higher level of vibration to the chassis than the stock mounts. I can see the vibrations in my side mirror.
08-30-2019, 06:05 AM
#13
1998 Boxster Silver/Red
Sir, they have the "P" on them. Clearly that is worth something.
1998 Porsche Boxster
