03-13-2019, 10:32 AM
#1
Coilover suspension question
Has anyone installed this Godspeed MMX3830 MonoMAXX Coilovers Suspension Kit For Porsche Boxster 986 96-04.
I'm looking to lower the car a bit to get rid of the big gap in the wheel wells.
Bill.
03-13-2019, 11:06 AM
#2
1998 Boxster Silver/Red
Welcome! Welcome.
1998 Porsche Boxster
03-14-2019, 01:44 AM
#3
Went though this about 6 months ago, lots of reviews floating around on them. I’ve ridden in and driven an auto-x specific boxster with godspeed coils and they felt fine. I personally went with Ceika because they were easy to build with custom spring rates and valving. I used PSS9 spring rates for my build since the car is driven fairly regularly but also sees some track and auto-x time.
What is your primary goal? Is your goal just to lower the car or is it to get maximum performance?
Shawn
-1999 Boxster 3.4L swap/NHP Headers/Fabspeed maxflow/ Coilovers/GT3 arms/adj. rear toe links/Tarret front and rear bar/UIDS/UAOS
-2002 911 Turbo -JRZ RS Pro/GMG swaybars/RSS/Billet k16s/ Markski turbo inlet pipe, tune, 3” exhaust, intercoolers/GT3 seats w/red GT3 belts/CCW classics
03-14-2019, 06:56 AM
#4
Shawn
Thanks for the information. I drive the car regularly during the warmer months. I also do 2-3 track/HPDE days a year. So I would like to up the performance and still keep it civilized enough for my wife to ride in.
03-14-2019, 07:12 AM
#5
I have H&R lowering springs on mine. Okay on the street and good at Mid-Ohio
03-14-2019, 09:56 AM
#6
Hello Van,
Out of curiosity, could you please share a couple of pictures of your car with the H&R springs?
I would love to see how much do they drop the car. Thank you!
03-14-2019, 10:42 AM
#7
Who's askin'?
These look CHEAP?!!? (as in- Inexpensive). I'd love to hear if anyone has used them.
I've been saving pennies for the Ohlins R&T series. I'm not sure why I'd buy Bilstein for $2400 when I can get Ohlins for $2700. But $600 for the Godspeed? huh... that makes a guy stop-n-think....
03-14-2019, 10:54 AM
#8
Here is my 200 S on H&R Springs 18" wheels
03-14-2019, 11:13 AM
#9
Thank you for the picture, you have a beautiful car!
And.. it looks great without being slammed, the H&R's were a good option congratulations!
03-14-2019, 11:39 AM
#10
Looks great.. what wheels are these?
03-14-2019, 11:45 AM
#11
Looks good w/out being slammed; i believe the 18" wheels raise it back up close to factory ride height but eliminates gap in rear wheel/fender
5280 Cruising @High Altitude
Seal Gray & K&N Filter
03-14-2019, 02:26 PM
#12
On the slippery slope
If you have the correct size tires, it doesn't matter if it is 17" or 18" wheels. The overall diameter should be basically the same, so the car height should be the same
255/40-17 vs 265/35-18 for instance
2004 996 Targa Tip
Instructor - San Diego region
03-14-2019, 02:28 PM
#13
Where'd you find $600?
The best I'm finding is $850.
03-14-2019, 02:32 PM
#14
I have thought the same thing.
Wiser and more knowledgeable track rats than me have felt the cheaper setups are just that, cheap and don't perform well.
I have no personal experience, so I can't specifically comment.
I track my Boxster often and have the ROW M030 setup with camber plates in the front and that setup works well. I get 2.5 camber on the front which made a huge difference. I have had better drivers than me drive my car and they loved the setup.
2004 996 Targa Tip
03-15-2019, 03:14 AM
#15
My Wheels are these from Wheel Dymanics
RS-808
18x8 (off-set 45)
18x10 (off-set 50)
03-15-2019, 05:25 AM
#16
Who's askin'?
Yeah, this is the same conclusion I came to about the cheap coilovers.... but wouldn't it be nice if I were wrong? haha.
I've got some LCA's that arrived, which I'll be installing shortly, with the intent of dialing-in some camber, for the same reason you've described. I'm afraid the coilivers will have to be NEXT winter. ::sigh:: ( In my mind, I'm both Richer and Younger. )
03-16-2019, 07:48 PM
#17
Maytag, you would not believe how much does the coil overs improves the feel of the chassis and with the ability to adjust separately, the compression and rebound as well, and combined with adjustable sway bars your car would be in a completely different level :-)
