Old 02-11-2019, 05:13 AM   #1
since95's Avatar
motorsport AOS install
Just wondering if anyone has any insight into a 996 motorsport AOS installation into a 2000S. I know it is going to need a bit of fabrication to mount it, but what do you do with the 80 degree bend at the bottom of the stock unit that goes back into the case? The motorsport is straight out of the bottom.
I have read a few of the older posts, but no one seems to mention what they did on the bottom. I thought about cutting off the tube from the old AOS and putting a hose over it and and the MAOS, but not sure if that will stay in the case.
I see LN has a bracket, but I have a tough time paying more for the mounting bracket than I did for the MAOS and different hose it needs!
since95 is offline   Reply With Quote
Old 02-11-2019, 07:41 AM   #2
BYprodriver's Avatar
This is the route I want to go if I have to replace my AOS again.
Old 02-11-2019, 07:55 AM   #3
steved0x's Avatar
Kevin at The Prosche Specialist in Broomhall PA has put one on one of the earlier cars, let me see if I can find the picture.
Ok it is for a 996 so maybe not the same
Porsche Motorsports Air Oil Separator Install Early 996 - THE PORSCHE SPECIALISTS
Old 02-11-2019, 08:31 AM   #4
that would be the same as an early 3.2"
shouldn't be too hard to fab but boy is it tight in that area.
Old 02-11-2019, 09:25 AM   #5
since95's Avatar
Thanks for the help. one of the other things I have found is the outlet I need to make some kind of a bend for is not located in the same spot as the original - so I will need to locate the MAOS and then figure out position of the bend. Might be worth buying a pre done bracket, but I have a bit of scrap 1/4 alumnimum around, so just need to draw something up and start making some chips.
I so like the simple bracket in the photo on the 996 mount - just need to figure out that angled outlet.
Winter in New England gives me plenty of time to figure it out!
