Old 02-11-2019, 06:13 AM   #1
since95
since95's Avatar
motorsport AOS install
Just wondering if anyone has any insight into a 996 motorsport AOS installation into a 2000S. I know it is going to need a bit of fabrication to mount it, but what do you do with the 80 degree bend at the bottom of the stock unit that goes back into the case? The motorsport is straight out of the bottom.
I have read a few of the older posts, but no one seems to mention what they did on the bottom. I thought about cutting off the tube from the old AOS and putting a hose over it and and the MAOS, but not sure if that will stay in the case.
I see LN has a bracket, but I have a tough time paying more for the mounting bracket than I did for the MAOS and different hose it needs!
since95 is offline   Reply With Quote
