Old 06-16-2018, 02:58 PM   #1
Hot Start Issue
When the car is warm or hot it has trouble cranking over, almost like the compression is higher.
No issues with battery & no codes.
Any idea's?
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 06-16-2018, 03:12 PM   #2
The compression isn't higher, the starter motor torque is lower. Bad starter or bad cables/connections can often cause this symptom.
It mostly happens when hot since the electrical resistance goes up with temperature; high temp => high resistance => low current => low starter torque=> engine barely turns over.
Old 06-16-2018, 04:08 PM   #3
Yep that sounds like it.
I'll check the cables & connections.
Thanks for your help
2000 2.7 Boxster
Old 06-18-2018, 05:31 AM   #4
flete25's Avatar
I had the same issue ...I bought the alternator\starter cable from sunset Porsche parts for $36 its an up grated cable compared to the original...this solved my issue the car cranks faster then ever
flete25 is offline   Reply With Quote
Old 06-18-2018, 05:00 PM   #5
Rennzenn
j.fro's Avatar
I had the same issue and it ended up being the starter.
Rennzenn
Jfro@rennzenn.com
Old 06-19-2018, 04:29 AM   #6
flete25's Avatar
what happens is that the alternator/starter cable from factory goes bad internally it may look ok in the outside part...when this cable starts to fail it will ruin your starter. it makes your starter super hot and weak.
