Thread: Hot Start Issue
Old 06-16-2018, 04:12 PM   #2
thstone
The compression isn't higher, the starter motor torque is lower. Bad starter or bad cables/connections can often cause this symptom.
It mostly happens when hot since the electrical resistance goes up with temperature; high temp => high resistance => low current => low starter torque=> engine barely turns over.
