04-13-2018, 04:42 PM
Clutch what did I do
I just replace my clutch and axles. bled the slave cylinder for and hour I can't get the pedal to pop back out the whole way. Pull the transmission again to make sure I didnt pop the arm off the pivot or disconnect something. Put it all back together again and I still have to pop the pedal up. New Spec 1 clutch and pressure plate replaced an old Spec clutch.
04-13-2018, 05:03 PM
I had the exact same symptoms. Replaced the slave thinking that was the problem but it turned out to be a cracked (plastic) clutch line that was leaking behind my fender. There’s an an upgraded version, IIRC.
More here: https://www.renntech.org/forums/topic/38449-small-puncture-in-clutch-line/
98 Arena Red 986
Is it just a fraction of an inch or is it a lot more? Your clutch assist spring may be broken if its just a little bit.
1941 Dodge Luxury Liner Coupe
04-13-2018, 05:13 PM
Comes up about 1/2 way then stops unless I Put my foot under it and lift. Almost like it catching.
04-14-2018, 02:05 AM
I agree, Your clutch assist spring may be broken, an easy ckeck above the pedal.
04-14-2018, 03:52 AM
still plays with cars...
Sounds like what mine did after a brake line flush.
My indie rebled the clutch line and all was good.
Six speed 2000 Boxster S
04-14-2018, 04:32 AM
If it ends up being the spring, I have a bunch of extra McMaster “upgraded” springs & can send you one for the cost of postage.
98 Arena Red 986
04-14-2018, 09:18 AM
OK I changed the brake pads and flushed the lines another time problem resolved. Thanks everyone for your replies, I should have done this first.
