Old 04-13-2018, 05:42 PM   #1
jsceash's Avatar
Clutch what did I do
I just replace my clutch and axles. bled the slave cylinder for and hour I can't get the pedal to pop back out the whole way. Pull the transmission again to make sure I didnt pop the arm off the pivot or disconnect something. Put it all back together again and I still have to pop the pedal up. New Spec 1 clutch and pressure plate replaced an old Spec clutch.
Old 04-13-2018, 06:03 PM   #2
I had the exact same symptoms. Replaced the slave thinking that was the problem but it turned out to be a cracked (plastic) clutch line that was leaking behind my fender. There’s an an upgraded version, IIRC.
More here: https://www.renntech.org/forums/topic/38449-small-puncture-in-clutch-line/
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
Old 04-13-2018, 06:03 PM   #3
Is it just a fraction of an inch or is it a lot more? Your clutch assist spring may be broken if its just a little bit.
1941 Dodge Luxury Liner Coupe
Old 04-13-2018, 06:13 PM   #4
jsceash's Avatar
Comes up about 1/2 way then stops unless I Put my foot under it and lift. Almost like it catching.
Old 04-14-2018, 03:05 AM   #5
I agree, Your clutch assist spring may be broken, an easy ckeck above the pedal.
philou320 is offline   Reply With Quote
Old 04-14-2018, 04:52 AM   #6
still plays with cars...
BoxsterSteve's Avatar
Sounds like what mine did after a brake line flush.
My indie rebled the clutch line and all was good.
Six speed 2000 Boxster S
Old 04-14-2018, 05:32 AM   #7
If it ends up being the spring, I have a bunch of extra McMaster “upgraded” springs & can send you one for the cost of postage.
98 Arena Red 986
Old 04-14-2018, 10:18 AM   #8
jsceash's Avatar
OK I changed the brake pads and flushed the lines another time problem resolved. Thanks everyone for your replies, I should have done this first.
