Old 04-04-2018, 02:12 PM   #21
Originally Posted by jaykay View Post
Yes....you could be right but I was not considering sheath collapsing onto cable persay.
I was considering or imagining compression of the cable run "arc" giving rise to restricted movement....IIRC cable operated fine when removed from the car.
The 987 with more clearance could eliminate this if it was a factor.
There should be NO binding AT ALL occurring at the firewall where the cables run through. I am talking about the shifter mechanism itself as a 987 unit. Much better overall. If your cables are binding for any reason, that is a significant problem, and needs to be addressed.
Old 04-04-2018, 02:31 PM   #22
jaykay's Avatar
Originally Posted by edc View Post
The fluid can leak. If you do it the above way it is a cheap mod to do. It's a shame to spend good money refreshing other suspension, balljoints and other rubber mount parts and not do these.
Alright....so really one should see traces of oil having leaked out
so:
-open assembly / drain oil
-pour in urethane into the bottom half with the stud plunger all the way down or in the middle of the housing?
-cure
-reassemble
986 00S
Old 04-07-2018, 05:25 PM   #23
ClayJ13's Avatar
Changed out the WEVO to the 987 motor mount today, and it made a huge difference. Thank you for the advice. I will be selling the WEVO part here soon...
ClayJ13 is offline   Reply With Quote
