Old 02-21-2018, 02:24 PM   #1
Seat removing
What is involved in removing your seats from ‘98 Boxster? Is driver side different from passenger?
davedeck is offline   Reply With Quote
Old 02-21-2018, 03:06 PM   #2
same thing side to side. Its 4 bolts and an electrical connector. my bolts were male torx so you'd need a female torx socket, but other than that its a piece of cake.
Old 02-21-2018, 03:41 PM   #3
2003 Base 5-speed
grc0456's Avatar
Also, disconnect the battery before disconnecting the under seat connection, as you will throw an airbag light that can only be cleared with a Durametric or factory computer.
Unhooking the connector is a little tricky as well, as it has a locking device - but there is a fairly good YouTube video to show you how.
Additionally, once the seats are out remember the rails are spring loaded, so try to stay away from the fore/aft release lever. If you bump it, the rails will misalign. They can be realigned (with some force), so it’s not the end of the world.
Old 02-22-2018, 06:09 AM   #4
The connector is a ********************.
Just an FYI, there are lots of aftermarket OBD2 readers that will clear airbag codes and abs, too. I've got this one: https://www.amazon.com/gp/product/B072FHD8LB/ref=oh_aui_detailpage_o06_s01?ie=UTF8&psc=1
2001 Boxster
2007 Toyota Highlander
Old 02-22-2018, 06:10 AM   #5
The connector is a b itch.
2001 Boxster
Old 02-22-2018, 09:55 AM   #6
Thank you gentlemen
Old 02-22-2018, 10:28 AM   #7
1998 Boxster Owner
I own that Autel and it works great - cleared my airbag light when I swapped my steering wheel
Benitom is offline   Reply With Quote
Old 02-22-2018, 06:50 PM   #8
2003 Base 5-speed
grc0456's Avatar
I stand corrected. Glad there are other options for clearing the airbag light.
Old 02-23-2018, 07:04 AM   #9
I didn't disconnect the battery when my seats were out. As long as you don't switch the ignition on whilst the seats are out you shouldn't get the airbag light on
pilch is offline   Reply With Quote
Old 02-23-2018, 12:44 PM   #10
2003 Base 5-speed
grc0456's Avatar
Right you are!
