Old 12-13-2017, 02:11 PM   #1
The shift is blocked. Help!
Hello, the shift of my 986s is blocked. I disconnected the 2 gear levers of the gearbox and the shifter moves perfectly, so problem is inside gerbox.
The lever of the gearbox is blocked is the one of red arrow in the photo attached in the link bellow. It moves the shifter from left to right and in the gearbox is the front small lever.
What do you think is the problem? I asumme thay need to open the gearbox 🙁
https://ibb.co/iut0aR
heiwaz is offline   Reply With Quote
