Old 11-19-2017, 12:48 PM   #1
Weigth loss: Battery
I´m trying to put my Box on a diet, without sacrifying to much of the streetability (is that a word btw?). I use it as a Daily driver, but also take it to the track.
My present battery is 42 Pounds, and as we all know placed high in the car.. Would love to address this somehow.
I have looked into standard "racing batterys" Braille, Odyssey etc, but so far not found anything that feels right. So I started to look at Lithium batterys, that give a bit more drastic weight reduction, but they are quite exepensive..
Came across this: Lithium starting battery lightweight racing The first one I found with more reasonable prices, but would it really work?
Any thoughts?
Old 11-19-2017, 01:29 PM   #2
Several: This are designed for race applications, as such they list CA or cranking amps, not CCA or cold cranking amps, which is what is important for street applications in cold environments like yours. The use a different charging profile than the alternator in your car is set for, and they have an extremely limited disposal/recycling chain (Li poisons lead, so they cannot be recycled together).
You can save some weight (7-10 lbs.) without all the above issues by going with an AGM battery such as the Optima or Odyssey, which are meant for street use in cold climates.
Old 11-19-2017, 02:10 PM   #3
jsceash's Avatar
You can buy an Odyssey PC925 for a round $153. I've been running one since 2012. I believe that the weight is 21#. You can also buy a Aluminum mount from about $38 to $150. The PC 925 has no problem cranking the car repeatedly or running accessories in traffic.
The Odyssey PC625 is pretty much designed for a track car starting 16#. I don't know how it performs in traffic with accessories.
Old 11-19-2017, 02:25 PM   #4
Originally Posted by jsceash View Post
You can buy an Odyssey PC925 for a round $153. I've been running one since 2012. I believe that the weight is 21#. You can also buy a Aluminum about mount from $38 to $150. The PC 925 has no problem cranking the car repeatedly or running accessories in traffic.
^^^^ What he said ^^^.
The Odyssey PC925 is fine for a street car and will save a lot of weight. I have a spare one sitting in my workshop.
I use an Odyssey PC680 my Spec Boxster but its a race car and I don't have any electric accessories. I wouldn't recommend a battery that small for a street car.
PC925 and PC680 installed;
Old 11-19-2017, 04:30 PM   #5
Topless's Avatar
Any thoughts?
I ran a 5lb Shorai LI battery in my Boxster for a few years.
The plusses: 5lb weight, fit in the tray fine with a custom aluminum bracket, good starting power when new.
The minuses: Very limited reserve power. Requires a very specific charger/maintainer to keep it healthy and it needs to be hooked up whenever the car is parked in the garage. May not work in very cold climates. If you use the wrong charger/maintainer or let it go flat once or twice, it will become damaged and no longer start your car.
It was effective as a track car battery but maybe too sensitive for a daily driven street car. I did have to push start several times after I abused the battery with a standard maintainer so my current car has a full size battery.
Old 11-19-2017, 06:50 PM   #6
I switched to a Miata battery and saved 20lbs. I’ve been using it for a year now without any problems. It does have a sluggish turnover though
Woody
Old 11-19-2017, 08:14 PM   #7
jaykay's Avatar
I have run a Odyssey PC925 for years. You don't want to go any smaller than that for a regular street driven car. You will have to plug it into a proper AGM maintainer if it is not driven regularly. This also keeps the battery healthy
986 00S
Old 11-20-2017, 08:21 AM   #8
Wow, this forum is really great! This is exactly the kind of info I needed, I´ll go for a Odyssey PC925, thanks all!
I have a C-tek MXS-5.0 I Believe that should work just fine.
Old 11-20-2017, 06:57 PM   #9
jaykay's Avatar
Rennline sells a custom holder for it
986 00S
Old 11-21-2017, 08:25 AM   #10
I got the Magnapower AGM ETK16L from pepboys. same weight as the expensive ones, but only $68 with discount.
Old 06-21-2018, 08:32 AM   #11
Smile
I can just confirm that I went for the PC925 and am very happy so far!
Old 06-21-2018, 02:12 PM   #12
BYprodriver's Avatar
I have a nice lite-weight Aluminum Mounting bracket for a 925 I'll sell for $40.
Old 06-23-2018, 11:27 PM   #13
I’m interested in your bracket if still a available. Tried to PM you for some pics but your mailbox is too full to accept new messages! Let me know, thanks!
Old 06-24-2018, 01:13 AM   #14
I've had a Miata battery in my boxster for for two years and they only seem to last one year before they lose their starting ability. I'm on my second one and it barely starts my car. I'm going back to a stock size.
Woody
Old 06-24-2018, 08:20 AM   #15
Deka ETX30L is the way to go.
I bought one on @topless’ recommendation & it’s better than expected. Out of caution, I put it in a maintainer when it sits for a week or so, but I have never had a problem starting.
98 Arena Red 986
Old 06-24-2018, 08:22 AM   #16
The Radium King's Avatar
braille is just a re-branded dekka with considerable mark-up.
Old 06-24-2018, 11:12 AM   #17
I have the bracket & I deleted some old PM's.
Old 06-24-2018, 12:50 PM   #18
