Old 07-09-2017, 07:04 AM   #1
Just extend the P/S vent line so it drips on the ground or into a little plastic jar. If that does not work the 2 "O" rings on the P/S Reservoir neck(not the cap) may need replacing &/or it was overfilled. Just keep the fluid at the minimum mark
Old 07-09-2017, 09:18 PM   #2
njbray's Avatar
Try putting on a new o-ring on the power steering reservoir cap. It stopped mine from leaking.
njbray is offline   Reply With Quote
