Old 05-10-2017, 10:42 AM   #1
01101
Suspected water pump failure
Got home last night and car was making an unusual noise. I took a video in the dark, and it sounds like other water pump failure noises I've heard:
https://youtu.be/eiEof53IOEU
Tonight I'll pull the belt off and crank it up to confirm. Anyone want to chime in with confirmation, or alternate theories?
Would this be safe to drive 30min to my friend's lift, or will I be stuck doing this at home on jackstands?
alm001 is offline   Reply With Quote
Old 05-10-2017, 11:00 AM   #2
01101
For anyone keeping track, this is only two days after buttoning up the alternator problems.
Old 05-10-2017, 11:38 AM   #3
If you suspect a bad water pump, I would not drive it two feet..........
Old 05-10-2017, 11:43 AM   #4
Porsche9's Avatar
....don't even run the engine.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 05-10-2017, 01:24 PM   #5
01101
What I think you guys are saying, is that I shouldn't drive it anywhere.
Jackstands it is then. Maybe next week, or the week after that.
Old 05-11-2017, 02:14 AM   #6
Rennzenn
j.fro's Avatar
Remember to flush the coolant in both directions. And when you think you've flushed it enough, do it one more time. Cracked heads are a ********************.
Rennzenn
Jfro@rennzenn.com
Old 05-11-2017, 07:46 AM   #7
#1 -if the impeller blades are missing chunks, you must retrieve all the missing pieces. They may be found in the Heat X !Not good.
Old 05-12-2017, 07:30 PM   #8
ISSIMI
I am not familiar with what a failing water pump sounds like. Is it the ticking in the video posted that's of concern? Other than that the engine sounded fine to me. From what I know aside from removing the belt and checking for play in the pulley or leaks a faulty water pump is difficult to diagnose. Does your car overheat? I plan to change mine the next time i do something coolant related so very interested in your outcome.
Most_Wanted is offline   Reply With Quote
Old 05-13-2017, 04:48 AM   #9
Good Luck on that! When my WP went, I had maybe 1/3 of the surface area of the blades shear off. I flushed and flushed, running everything through a big sieve I picked up somewhere or other. Never recovered a single piece. The good news: that was several years ago--not a problem has surfaced since, cracked head or otherwise. Do what you can, then drive it!
Frodo is online now   Reply With Quote
Old 05-13-2017, 07:05 AM   #10
01101
The ticking is normal... But on the video right around 22seconds I move the camera under the car in front of the passenger rear tire. At that point you can really hear the sound I would describe as a diesel truck idling.
I may have time to get the car apart and up on jacks later today to confirm.
