Old 02-05-2017, 11:54 AM   #1
steved0x's Avatar
OEM manifold to midpipe gasket question
I sent my mid pipes out to be ceramic coated, and bought these gaskets for when I reinstall them. They look awfully thin and tiny, but they are the OEM Porsche gaskets. I guess this style is what came out when I installed the pipes the first time, but they are a lot different than what came with the mid pipes from top speed. Anything special to know about installing these, does it matter which way the raised circular flange on the gasket goes when I put them back on?
Steve
Old 02-05-2017, 12:38 PM   #2
I had the same concerns as you I wish I could find some " conventional " thicker gaskets for both the header to head and the transition joint . Maybe these thin gaskets work but I would prefer something thicker that would compress as it seals .
Old 02-05-2017, 01:12 PM   #3
Steve
Torqued to spec, they work fine. Be aware that there are different sizes for different engines.
Old 02-05-2017, 01:16 PM   #4
steved0x's Avatar
Good to know, I got the part # from the pet for my year.
The top speed gaskets were thicker and compressed, I just checked them, when I removed the pipes one fell off in pieces. I don't think they ever leaked, but they are definitely single use...
Old 02-05-2017, 01:54 PM   #5
We have never had any problems with the factory thin stainless gaskets.
Old 02-05-2017, 02:46 PM   #6
steved0x's Avatar
Great, thanks a lot JFP, I was hoping you would chime in
Old 02-05-2017, 03:53 PM   #7
So to Steves original question does it matter how the raised portion of the thin gasket is installed ? Facing forward or facing rear word or it doesn't matter ?
Old 02-05-2017, 06:06 PM   #8
Does not matter; the raised portion of the gasket is designed to be crushed to form the seal, which side it is on is irrelevant.
Old 02-06-2017, 06:39 PM   #9
BYprodriver's Avatar
Try ROL #EG24154
Old 02-06-2017, 07:09 PM   #10
I checked what I've got, and found OEM brands Elring and Victor-Reinz for the manifold-to-head and manifold-to-triangle flanges had similar, embossed 1-layer stainless steel construction:
Probably the best thing you can do to get these to seal is to make sure the sealing surfaces (on both sides) are perfectly clean and flat.
If additional compliance were important, the gaskets could have been designed to use multiple layers, which is called multi-layer-steel (MLS) gasket. MLS gaskets are very effective for reliable head gasket seals. They can seal a lot of pressure, while maintaining compliance as the surfaces expand and contract through temperature changes.
2001 Boxster
Old 02-06-2017, 07:16 PM   #11
steved0x's Avatar
I've got the same manifold gaskets too but decided not to change the manifolds after all (too expensive to ceramic all my pieces including my spare manifolds) so leaving the originals on. If I ever get to where they don't keep.up with the efficiency codes I will swap then...
Old 02-07-2017, 11:35 AM   #12
The Top Speed thicker gaskets are utter crap, I had the centre part of the gasket disintegrate and blow out after only a few months. The originals are perfect.
Dualist is offline   Reply With Quote
Old 02-21-2017, 05:53 PM   #13
steved0x's Avatar
Getting ready to put my stuff all back together and the Porsche gaskets I got (99611111302) are too small, they must be for the 2.5 dang it... [edit: Some] of the parts sites don't seem to show a different gasket between 2.5 and 2.7/3.2. These are definitely smaller.
I'll hit O'Reilly tomorrow and get the aftermarket brand listed in the previous post...
Edit: Looks like I should have ordered:
99611311300 - 2.7/3.2
99611111302 - 2.5
Oh well at least it was only about $1 each.
Old 02-21-2017, 06:14 PM   #14
996-113-113-00 are the larger gaskets, 996-111-113-02 are for the 2.5L.
Old 02-21-2017, 06:54 PM   #15
steved0x's Avatar
Thank.you, those are the parts dang it.
