Old 09-11-2016, 08:02 PM   #1
Engine Oil for 2001 986
I have been using Mobil 1 10/40 M Formula for my base 986, I live in the Central Valley of California, cold weather isn't a problem here. And no, I have not replaced the IMS and have had no signs of trouble on a car with 42K Miles.
Can I use 0/40 M Formula and not cause myself any additional risk?
Old 09-12-2016, 12:21 PM   #2
Ciao's Avatar
The only additional risk is not changing the oil regularly.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 09-12-2016, 12:25 PM   #3
Not a problem, gets new blood every 3000 to 4000 miles. I like to keep a short leash on checking the filter for any metal shavings (none so far, thank God)
Old 09-12-2016, 12:33 PM   #4
Mig
Hi.
What's the reason for not sticking with the 10W40? Is it just getting harder to find?
Mig is offline   Reply With Quote
Old 09-12-2016, 12:46 PM   #5
911monty's Avatar
I also live in California and since it never gets below ~20 deg 0W-40 is not required. I ran M1 0W-40 for one change and did not like the startup clatter. 5W-40 or 10W-40 from now on.
Old 09-13-2016, 06:48 AM   #6
lkchris's Avatar
With Mobil 1 last time I checked the Porsche oil is 0W-40 European Formula. "Formula M" in contrast describes oil meant for Mercedes diesels.
In any event, the oil should include "Meets Porsche A40" printed on the container.
In addition, there is zero advantage to 10W-40 versus 0W-40 in any conditions.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 09-13-2016, 08:44 AM   #7
78F350's Avatar
You might as well be saying, "Zero is a better number than Ten." unless you have facts to back it up or personal experience to quantify it. Not saying you are wrong, just that I see no basis for your statement.
Old 09-13-2016, 01:33 PM   #8
911monty's Avatar
Oh then try the inverse. Since I live where the temps I drive in are 50 to 100 deg f. there is zero advantage to running 0W anything. In fact my Owners manual states 5W-40, 10W-40 and 15W-40 are recommended.
However If you read Lubrizols ( major developers of Viscosity Modifiers)papers on the subject you will find that the 0W oils start with a 10 or less viscosity base stock, then through the use of long chain polymeric modifiers increase the viscosity to 30W 0r 40W. Since there is the potential that the molecular chains can be sheared and reduce the oil viscosity and since I drive in a lot of 90 degree temps, I choose to have a higher viscosity base stock to begin with.
I attempted to not start another oil war by saying the oil is not REQUIRED and only related my experience with 0W-40.
I'll add a few links for some reading.
A simple primer:
http://www.machinerylubrication.com/Read/1327/viscosity-index-improvers
Link to Lubrizol
http://hddeo.com/ViscosityModifierPart2.html
There is certainly much info on the subject eg Bob's the Oil Guy. I don't profess to be the authority, I just don't follow the crowd. I do my own research and use my best judgement. YMMV
Old 09-13-2016, 02:21 PM   #9
Okay, I think I am totally confused. I was curious because I was running Porsche spec'd 10/40W Mobil 1. Now Walmart is selling 0/40W Mobil 1 (Porsche spec'd) for a heck of a price (5 gal for $22.58, okay I'm a cheap bastardo always looking for a deal). My oil is changed every 3 to 4K miles. So with winter approaching (if you want to call it winter in California) I thought getting an oil that gets less thick as it cools, should I really be that concerned.
So, should I be a cheap bastardo under my particular circumstances ?
Old 09-13-2016, 02:33 PM   #10
911monty's Avatar
These are my opinions only! The oil commercials are somewhat misleading when they state 0 viscosity oil gets there quicker on startup. Let me throw this out there. The oil pump in your engine is a POSITIVE DISPLACEMENT gear pump, hence the need for an oil pressure relief valve. This means that for each revolution of the pump a precise volume is moved unless there is blockage, then the relief valve opens preventing overpressure and damage. This also means that any viscosity oil that can flow without the relief valve opening will arrive at the exact same time. Since we live in temps where the relief valve is not likely to open IMO 0W is not REQUIRED, If you wish to run it is also ok. Now if you live where you're starting your car @ 0 and below then it is required.
Old 09-13-2016, 02:43 PM   #11
What you should really be thinking about is anoil's flim strength and a given product's ability to stand up to high temperature/high shear conditions without falling out of grade. Then the differences between a 0W and 10W-anything become much more obvious, regardless of the minimum ambient temperatures.
Old 09-13-2016, 06:26 PM   #12
So for an idiot like me, am I good with the 0/40W Mobil 1 Porsche spec'd earl?
Old 09-14-2016, 06:46 AM   #13
You are an excellent candidate for Porsche A40 approved Mobil 5W50.
Old 09-14-2016, 01:33 PM   #14
Depends upon what you want. We do not use any 0W-40 M1, and have not for many years now. The are much better oils available now that offer far superior engine protction. We also do not use any 0W-anything oils due to low film strength issues inherent to zero weight oils, regardless of the manufacturer, and stopped using Mobil 1 products completely not long after Exxon acquired them and started reformulating the line.
Old 09-14-2016, 02:56 PM   #15
What you have blundered into is an area where there are strong opinions and even a few based on facts. There are forums devoted to the subject (like this one) and, even after hundreds of postings, still differing opinions.
There are folks whose experience inside the M96 engine exceeds 1,000 that don't use any Mobile product. There are tens of thousands of P-car owners who do. An oil developed with Porsche is mind is Joe Gibbs DT40. May be tough to get though depending on where you live.
Old 09-14-2016, 05:14 PM   #16
W is for Winter
I can't believe that people are still getting this wrong. The viscosity of an oil at operating temperature is always the higher number. The 5W or 0W is only the winter rating or viscosity as 0 degrees Celsius. Even youtube car "experts" get this wrong.
ALL oils are thicker when cold, though ideally they should be a consistent viscosity at any temperature.
This is true with conventional oil, but synthetic base oils are inherently multi-grade and don't need friction modifiers (link to reference)
Bottom line is look at the back of the bottle for the Porsche A40 spec. If it's there, you are good to go, otherwise use at your own risk. Note that formulations change all the time, so oils previously having the Porsche A40 rating may no longer be approved. For example, the Mobil1 15W50 oil which was Porsche A40 rated a couple months ago is no longer approved in favor of the new 5W50 oil. There are no 10W40 oils that are on the Porsche approved list.
newBgeek is online now   Reply With Quote
Old 09-14-2016, 05:17 PM   #17
Good to know, thanks.
Are there any particular brands you do suggest and weight? Like I said I have a 2001 Base with 43K miles and not replaced the IMS. I live in California and we have very mild winters (that is even a stretch, rarely hits freezing, and I actually rarely drive it in the winter, only on trips to the coast). Appreciate any help on this matter.
Old 09-14-2016, 05:20 PM   #18
Very interesting, thanks for the input. What a confusing subject on what seems to be a straight forward issue.
Old 09-14-2016, 06:46 PM   #19
"50 Years of 550 Spyder"
10/10ths's Avatar
Salvation....
...lies within:
https://www.amazon.com/Joe-Gibbs-Driven-Racing-Synthetic/dp/B0095FBP5U
Old 09-14-2016, 10:38 PM   #20
JayG's Avatar
Motul 8100 excess 5w-40 is another great oil to use
On amazon ~ $150 for 4 x 5 liter bottles delivered
