Old 08-05-2016, 03:17 PM   #1
New Porsche Fan
imari's Avatar
Need Immobiliser advice
I have a 01 Boxster that won't start. I am almost 100% sure that it's the immobiliser but I'm not sure of the next steps.
The alarm went off, I unplugged the battery to stop it, reconnected it and everything works BUT it won't start. The carpet is soaked so I removed the seat to find a good amount of water underneath. I removed the immobiliser to have dried the box and circuit board. I do see some corrosion and there was some condensation and water inside. I'm not sure if it will still work or not. I plan to let it completely dry and then reinstall to test (btw do I have to reconnect the seat wiring of just the immobiliser unit to test?).
Has anyone had this issue and successfully repaired it? Do I need to go online and buy another circuit board if this doesn't work??? and if I do should I get another key, transponder, ignition, etc to go with it??? Does it have to be reprogrammed by a dealer???
Any advice would be greatly appreciated.
2001 Black Boxster
2004 Red Vespa 150cc
2006 Black Maserati QP
2008 Black VW Eos
2010 Charcoal Ford Flex
imari is offline   Reply With Quote
