Old 08-05-2016, 08:48 PM   #4
Gelbster
The cause of the leak may be blocked drains. Clear with coat-hanger wire and compressed air.Search for details.
IMHO it is all a waste of time unless you drill a drain hole in the floor at the lowest point. Sooner or later there will be another flood and you'll have the same problem. A couple of ziplock backs around the immobilizer case may work perfectly. But if the water can't drain away it will create a puddle there.
