Old 07-05-2016, 10:31 PM   #1
Rear Barkes Won't Bleed
Am unable to bleed rear brakes. Open all 4 nipples & the pedal is still hard.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 07-06-2016, 05:16 AM   #2
I'd check for a pinched brake line
Woody
Old 07-06-2016, 05:30 AM   #3
steved0x's Avatar
Are the bleeders really corroded or clogged? In my old Tacoma I couldn't bleed one of my rear drum brakes and it was corrosion in the bleed nipple.
Old 07-06-2016, 06:34 AM   #4
steved0x's Avatar
I just saw your thread on RL, you replaced the brake booster and this is the first bleed after doing the brake booster?
I've never done those, but here is a video of the process, maybe this will provide some clues?
https://www.youtube.com/watch?v=LsVANgHiR84
Old 07-06-2016, 07:00 AM   #5
Racer Boy
Racer Boy's Avatar
In my experience, it's the bleed nipples. They get corroded and plugged.
Old 07-06-2016, 01:36 PM   #6
Logically ,you work forward from the bleeders and slacken every union/connection until you find the first one that weeps brake fluid. Then start purging until you get clean fluid coming through.
It would be much easier to assume corrosion in the nipples and remove one completely and inspect.
I'd guess that the union on the caliper will weep if you slacken it? In which case it is almost certainly corrosion in the nipple.
Unless someone fitted Automatic Bleed Valves?
Old 07-06-2016, 02:04 PM   #7
What the OP is not telling you, but is posting on other sites, is that he has an ABS module that is not responding to a questionable Durametric system (possible clone, but software version is at least 10 years out of date). This possibly indicates a wiring or ABS module problem, but with the system he is using to diagnose it, nothing is certain at this juncture.
Nothing like trying to diagnose a problem without all the facts................
Old 07-06-2016, 02:24 PM   #8
Agreed !
Waste no more time - close thread.
Old 07-11-2016, 04:44 PM   #9
Thanks JFP. The version of software is approx the same vintage as the car.
It seems from the feedback on various forums that the problem is in that the unit is a clone so I'll buy one direct from Durametric & hopefully it resolves the problem.
I incorrectly assumed that a non genuine unit would perform similarly to an original much the same as many after market parts do.
Thanks to everyone that provided feedback to the thread.
2000 2.7 Boxster
Old 08-09-2016, 08:00 PM   #10
Purchased an enthisiast Durametric. Soes anyone have a step by step secondary bleed procesure for a 986 using a durametric?
2000 2.7 Boxster
