Old 05-08-2016, 04:02 AM   #1
AFAIK as i know there is no bore. But the main problem seems that the 2.5 ECU doesn't have an input channel for a second cam sensor. So how will you get that to be worked? After market race ECU with individual software? Newer ECU that has to be flashed to older values? Very difficult.
Regards, Markus
Thanks Markus.
I was hoping the ECU could be hacked/ programmed to read the sensor. After all the US software already has this capability, so the hardware is likely the same. Surely someone have found ways to hack the software of these cars?
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Bebbetufs is offline   Reply With Quote
