Old 04-09-2016, 02:39 PM   #21
still plays with cars...
BoxsterSteve's Avatar
Good sleuthing!
Congrats on getting your Box running again.
Originally Posted by nyranger6830 View Post
So the long process is over. The issues was the Immobilizer. I was saved when I read this post from Pedro and i suggest anyone who runs into an issue with their's, try this first before replacing:
"Try removing the driver's seat and then the CLU.
Disconnect it from its harness, remove it from the car and open the case.
Remove the printed circuit board and dunk it in a shallow recipient and cover it with isopropyl alcohol.
Shake it well so the alcohol penetrates all the spaces, in particular between the chips and connections.
Then, let it dry. You can accelerate the drying by using a hair dryer in the cool mode.
Dry out the inside of the case if it had humidity and put everything back together.
If it was water causing the problem, it should now work fine.
We have saved many CLUs this way."
Thanks everyone for your help!:dance:
Six speed 2000 Boxster S
Old 08-06-2022, 12:51 PM   #22
Thanks for this, it just saved my bacon!
LiteCurves is offline   Reply With Quote
