Old 01-26-2016, 03:37 PM   #1
geraintthomas's Avatar
Rear light wiring question
I bought an LED ready relay for my LED indicators but it didn't fix the problem, so I'm fitting resistors to the indicator wires.
With the rears, I'll do it to the wire plug, but there's 6 wires. I found these two diagrams though:
Could someone confirm that the left light cluster's indicator wire is number 4 being white and black, and the right light cluster's indicator wire is number 3 being black and... grey? Green? I haven't checked yet but what would GR be?
Thanks!
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
Old 01-26-2016, 05:16 PM   #2
1999 base
Meir's Avatar
To answer part of your question, GR or GY is gray. Green will by GN.
if I'm reading your post correctly, you are trying to replace the regular blinker bulbs with LED.
If that is the case, take in mined the in the Porsche lights plate, the positive is the common, and the lights output is negative.
In other words, the outer contact of the bulbs get 12volts positive, and the center contact gets negative.
While withe a regular bulb polarity doesn't matter, it does with LED's.
All the "of the shelf" LED's I found, are reversed in polarity.
Old 01-27-2016, 12:30 AM   #3
Ah that's fine. I've tried the bulbs and they work just fine, it's just the fast flashing I need to fix.
The resistors are attached to the positive and negative/ground wire of the indicator bulb. If I attach it to the black & white wire, and then onto the brown wire, would it affect any other bulb in the housing? As they look like they share the same ground.
Old 01-27-2016, 02:01 AM   #4
No, they won't affect anything else. However, they get very hot, even on the intermittent circuit of the flasher, so keep them away from plastic and other wires.
particlewave is online now   Reply With Quote
Old 01-27-2016, 08:49 PM   #5
Mig
I'm speaking in general terms, but why not just put in a new flasher relay designed for LEDs?
Mig is offline   Reply With Quote
Old 01-28-2016, 12:27 AM   #6
I did as mentioned in the original post but it didn't work. Rather than keep buying relays, I know this method works.
Old 01-28-2016, 09:03 PM   #7
Mig
There it is, right in the first line. My mistake.
