Old 01-17-2016, 10:08 AM   #1
Rad fan resistor fix
So both my rad fans wouldn't run on low speed due to the resistors being knackered.
I simply refused to pay £67 per side to solve the issue so decided to find an alternative way to fix them.
After a bit of looking around I bought a couple of high quality resistors and made up my own harness. Removed the old resistors today and fitted my new harnesses whilst I was fitting new condensers and I now have fully working rad fans again with two speeds
Grand total cost? £4.62
I'm going to run the car for a bit and if I don't get any issues I will consider making up kits for people for a small fee if there's enough interest
The new resistors I have used are far superior to the factory ones and they also have a large heat sink on them which should help stop them from dying as easily as the standard ones.
Sideways Steve is offline   Reply With Quote
Old 01-17-2016, 10:48 AM   #2
Great job! Many of us have done the same and its not very hard.
Hopefully others will see this post in the future and be inspired to DIY also!
Old 01-17-2016, 03:33 PM   #3
geraintthomas's Avatar
Love these sort of fixes
Porsche Boxster S Type 986
Old 01-21-2016, 10:02 PM   #4
details please.?!
thanks
Sassmatt72 is offline   Reply With Quote
Old 01-22-2016, 09:08 AM   #5
http://www.renntech.org/forums/topic/37254-radiator-fan-question/
Old 04-04-2016, 07:18 PM   #6
ksjohn's Avatar
I am looking for some details on an alternative radiator fan resistor to the expensive OEM version.
Can anyone provide some details for an alternative resistor? Source? Part Number? Specs?
ksjohn is offline   Reply With Quote
Old 08-09-2016, 05:24 PM   #7
What spec are the resistors?
Escy is offline   Reply With Quote
Old 08-09-2016, 08:45 PM   #8
Here is an interesting ,related thread for older P-Cars that gives the basic elements of the discussion
Ballast resistor/oil & AC fan low speed resistor - "redesigned" - Rennlist Discussion Forums
http://rennlist.com/forums/996-forum/857242-cooling-fan-resistor-3.html
http://www.arcolresistors.com/resistors/hs100/
https://www.amazon.com/uxcell%C2%AE-Aluminum-Housed-Wirewound-Resistor/dp/B0087ZCZ9E
A thermo switch seems like a good addition?
Old 04-21-2017, 10:43 AM   #9
Hi Sideways Steve,
I too live near Glasgow, are you able to give me some more feedback on how your resistors performed long term as I'm having a problem with mine and I'd like to do a fix.
Cheers
Jeff8529
Jeff8529 is offline   Reply With Quote
