01-15-2016, 11:16 AM
#1
spare key question
So, when I bought the car, the guy I bought it from gave me 1 complete key, and another key that had no internal electronics, just the glass capsule. My question is, if I ever lose the good key after locking the car with it's key fob, would there be any way of switching off the alarm if I had to manually open the door with the the other key?
01-15-2016, 01:00 PM
#2
1999 base
yes.
you open the door with the key, and then turn the ignition on.
that should turn the alarm off.
01-15-2016, 01:12 PM
#3
@Meir:
Yes, but only if the key has a transponder that is recognized by the alarm system.
@boxster:
The glass capsule is the transponder.
Regards, Markus
01-15-2016, 10:28 PM
#4
Ok, that's great to know then, thanks a lot guys. Yes the key has a transponder, it starts the car no problem. I just want to know if I'm "safe" with the spare key just in case I ever lose the other one. I thought its not much good having a spare key if I wouldn't be able to switch off the alarm then. As long as I know the alarm can be easily turned off I don't need to go spend money on another key, the one I have is enough. Will the alarm remain off then, or will it come on again when I switch off the car and take the key out of the ignition?
01-16-2016, 06:29 AM
#5
On the slippery slope
If the key starts the car, you are good to go
If you want to get another key head with the electronics in it they are about $130 from genuineporscheparts.com. Then you need to get it programmed at a Porsche dealer $50-$150. Only a dealer can program the keys
2004 996 Targa Tip
Instructor - San Diego region
01-16-2016, 07:31 AM
#6
Hi boxster,
is you spare key a fob key? If not, please hold the transmitter (glas capsule) beside the key and try to start the car. If it doesn't start the transmitter will not be recognized by the alarm system and might not work for you car and you won't get it startet if you loose your fob key.
If your spare key is a fob key, just try to start the car with it.
Regards, Markus
01-16-2016, 12:20 PM
#7
Originally Posted by Smallblock454
Hi boxster,
Regards, Markus
Yes its a fob. As I said, I can start the car no problem with the spare key, I obviously can't lock it with the fob, I have to lock it manually, but as I just want it as a safety net just in case I lose the main key, then its good to know that I can turn off the alarm by putting the key in the ignition. I don't need to spend money on a spare key since I have one that I can work with.
