Ok, that's great to know then, thanks a lot guys. Yes the key has a transponder, it starts the car no problem. I just want to know if I'm "safe" with the spare key just in case I ever lose the other one. I thought its not much good having a spare key if I wouldn't be able to switch off the alarm then. As long as I know the alarm can be easily turned off I don't need to go spend money on another key, the one I have is enough. Will the alarm remain off then, or will it come on again when I switch off the car and take the key out of the ignition?
