Old 09-03-2015, 03:47 PM   #1
truegearhead's Avatar
All of my left rear lights are out, help
So a week ago my left brake light went out. I changed the bulb but it still didn't light up. Now all my lights on left tail light are out except my blinker. Any ideas? The bulbs are fine as well as the fuses.
truegearhead is offline   Reply With Quote
Old 09-03-2015, 04:41 PM   #2
Brake light switch? Right side works, so wouldn't be that...
Are the lefts on an independent circuit and fuse? If so, check for power there... replace the fuse with a tested good while there, even if the original looks good.
Check the harness behind the light housing to see if you're getting voltage there...
ianacole is offline   Reply With Quote
Old 09-03-2015, 04:48 PM   #3
steved0x's Avatar
Sometimes the metal tracings on the bulb holder can lift up. Or, since you were recently in there, maybe the connect to that side didn't seat and has popped mostly off?
Old 09-03-2015, 04:51 PM   #4
Check your light switch. Had a similar problem that affected rear lights, head lights. Replaced switch and problem solved.
Conchman is offline   Reply With Quote
Old 09-04-2015, 06:03 AM   #5
Bingo! I rattled the switch the around and the lights came on. Thanks
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
